Spring plate question
Just cleaned all the rubber bushing residue off my spring plates to send them off for replating. Had them laying flat on my workbench and noticed one side is actually bent. Laying flat on the table, it's roughly 3.5mm off at the highest point. These are the factory standard adjustable ones.
Question: should I replace these? |
Just bend it back.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
PCA Member since 1988
^^ this.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
