Polishing Fuch Lips
I think my Fuchs have an anodized outer lip. Is that correect? If so, does anyone have a simple step by step process on how to polish these outer lips?
Old 06-08-2003, 09:32 PM
Yes,Stock their anodized. Send them to Al reed to have the anodizing removed and polished. There are lot's of ways you can re-do them.
Mine are polished and the centers painted and then clear powder coated on the centers only. This process will keep you from having blisters on your fingers.
Old 06-08-2003, 10:37 PM
jphillips-998's Avatar
I am in the process now. Not going for a true "concours" look but just wanted to clean up a bit. The results have been pretty amazing.
I rubbed w/000 steel wool first. Then, working in VERY SMALL sections applied rubbing compound and hit it w/a drill polishing pad. Very small means an area that you can easily finish while the polish is still wet.
After that hit them w/polishing compoud again with the drill, then Mothers Metal Polish by hand.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 06-08-2003, 11:16 PM
one of gods prototypes
bell's Avatar
al reed is the way to go.......i did mine over the winter and think next time i'll send them out
the easiest way to remove the anodization is "easy-off-oven cleaner" in the yellow can, apply.....wait 45 minutes.....clean off......apply....wait another 45 minutes.....clean off.....no more anodization.
then start sanding.
i picked that up on the bbs.......and it worked great....but be forewarned.......polishing your own fuchs requires TONS OF ELBOW GREASE.........
have fun
Brought to you by Carl's Jr.
Old 06-09-2003, 06:21 AM
