Calibrate lc-2 in tunerstudio
Hello,
I installed the bitzracing kit and noticed readings of my LC-2 AFR in logworks and in tunerstudio are different. I found that normally you can calibrate the sensor in Tunerstudio but there's no option in mine. I can only calibrate TPS. I suppose MS1 is the reason or can I set this in the correct way so readings are correct? |
| All times are GMT -8. The time now is 02:02 AM. |
