Former Options Trader !!!
6 x 15 Cookie Cutter offset?
Anyone know the correct offset on these ? (6 by 15)
Is 36mm correct? Thanks
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
PCA Member since 1988
No. Should be about 12. 36mm probably came off a 924 or 944.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
15x6 should have a 36mm offset
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
banalytic
36mm are correct for 6J15 for early 911, starting with model year 1973...
Thanks everyone. I was thinking 36mm was correct.
Much appreciated
Thanks for the correction. That's the second time I've misremembered some data in as many days. I better quit now...
