-   -   Tinkercad & SendCutSend for doing compressor mounting plate (http://forums.pelicanparts.com/porsche-911-technical-forum/1141623-tinkercad-sendcutsend-doing-compressor-mounting-plate.html)
Discseven 07-06-2023 10:15 AM
http://forums.pelicanparts.com/uploa...1688666501.jpg
Test fit looking at oddball corner. Prior slider plate I had had no mount from the slider to the compressor here. Reason is obvious. I could have skipped it too in this plate remake but think there’s just enough space to make a 4th bolt work. Jam nut here is certainly not optimal but better with a bolt & jam compared to no bolt at all. Will get rid of the powdercoat where the jam nut seats. Blue lock it. If necessary, can hog off a bit of flange or bracket material. Thin wavy? Bolt shaft = 40mm. Spacer = 3/8". Bracket = 1/2" thick.
thetorch 07-06-2023 05:02 PM
I have been using QCad Pro ($38) because it's Apple Mac native and pretty easy to use for 2D only. A couple youtube videos about how to use and you will be off and running.
Gonbad 07-06-2023 05:30 PM
Originally Posted by SBell (Post 12038493)
I would recommend Fusion360 for beginner friendly CAD programs. The hobby license is free at it has a lot of available functionality once you are ready to go deeper. I found out a long time ago I really quickly ran into the limits of TinkerCAD when trying to edit parts I already made without breaking other parts of the model. Then again that was probably 8 years ago so they've probably made some changes since then.
Sent from my SM-G991U using Tapatalk
What he said http://forums.pelicanparts.com/support/smileys/dom.gif
You do however need some pretty good graphic processing power.
Showdown 07-06-2023 06:36 PM
I use both sketchup on my Mac and shapr3d on my iPad Pro. Both have their pros and cons- shapr3d is super intuitive and easy to use but neither are as powerful as fusion360 but conversely shapr3d took almost no time to learn.
