1973 911 e cdi box smoking?
hi ya. something strange happened a few days back. im trying to get my 2.4 e mfi running good. had it idling for a little. then i started to smell and see smoke coming out the right side of the engine. i shut the car off. it didnt smell like burning,oil. though maybe a few drips of oil leaked onto the heat exchangers. it looked like it was coming from the cdi box. could the cdi be smoking. im assuming its the original box. i had the car since around 2010. any thoughts?
Old 07-06-2023, 10:53 AM
PCA Member since 1988
If the engine was still running, very unlikely that the CDI box was the source of smoke. If it got damaged, the ignition should have stopped. When electronics overheat, they have a distinctive acrid smell. Did it smell like that?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-06-2023, 12:27 PM
