G50 Clutch + While You're in There...
At 151k miles and with a stiff clutch pedal I knew it was a matter of time, and that time was this past Saturday. I was close to home and the clutch started to slip as it struggled to engage in gear. I have a list below and would like any quick feedback and some thoughts on specific questions below. Thanks to the forum archives for helping me get this list together so far.
Clutch Questions:
Thoughts on replacing both the master and slave cylinders?
While You're In There (WYIT):
Fuel Lines: I have factory lines. Is the guidance to replace only the lines in the engine compartment?
Starter: No current issues with the unit, but at 151k miles and the engine dropped, is this worth knocking out?
Thanks,
-Mike
-Mike
1987 911 Carrera Coupe
Old 06-05-2023, 11:54 AM
Following.
Old 06-05-2023, 09:22 PM
Cory M's Avatar
Personally I wouldn't replace the master/slave cylinders or fuel lines unless there is a problem.
The mounts for the clutch fork pivot shaft are a known weak point. The bearings in the pivot can seize up and the bosses break. I recommend doing a very thorough inspection. Worth doing a dye penetrant inspection if you can to identify cracks. I would replace the pivot shaft and bearings with new parts. I believe this part (bushings/bearings) was redesigned by Porsche at some point, so there should be documentation out there. I had them fail on my transmission and I sent it to California Motorsports.
https://californiamotorsports.net/collections/porsche-g50-transmission/products/cms-g50-993-gt3-clutch-fork-pivot-shaft-boss-repair
Inspect your guide tube as well. If it's worn out replace it. I've had them hang up on the new throwout bearing because of wear causing friction and binding(this was on 915 but same principle).
The rubber transmission mount bushings could be replaced while you have it apart.
Edit- I see now that you have the guide tube and pivot shaft on the list already.
Old 06-05-2023, 10:02 PM
Behind the Sun
Grease CV joints and new boots
Old 06-06-2023, 06:20 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I changed my G50 clutch about a year ago. Did the fork upgrade and the non rubber disk clutch. I also ended up replacing both the master and slave. The gunk that was in the lines at the slave was nasty. Glad I did both while in there. Getting the lines back on the slave is a bit of a pain so I would not want to have to do it twice. With that many miles, I would replace.
Stock clutch works perfectly and will do a minor burnout without having to dump the clutch too aggressively.
Chris
89 Carrera
Old 06-06-2023, 08:45 AM
Red Line Service
Marc Bixen's Avatar
You may want to look into this also, updated thicker ring gear, if yours shows wear or if it ever grinds: 950 116 143 05. Most times you will need a slave because the plastic tip wears out! And I STRONGLY recommend using the factory roller bearing cross shaft, NOT the bronze bushing style! Poor or old lubrication of the bronze bushings can lead to premature failure of the case ears as Cory M speaks of. High clamping force pressure plates also cause these failures. CMS's repair is very well executed if necessary. ,Also, if you do the valves, get a complete VC gasket set . Wrightwood Racing is the best. Some others use very soft alu washers, that can be a problem next time.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 06-06-2023, 09:00 AM
Good info and helpful.
I did the valves ~1000 miles ago. It was my first time, so I want to do them again since I have easy access. Can/should I re-use the hardware or just spend the $40 and start fresh?
-Mike
Old 06-06-2023, 11:44 AM
Easily Confused
dtxscott's Avatar
Both speed and reference sensors and the CHT.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 06-06-2023, 01:25 PM
Got the big lump dropped this week and will start tackling things as parts roll in.
Couple of questions:
What are opinions on replacing things that are original but not broken? For example:
Starter
Speed/Reference sensors (CHT was done about 10k miles ago)
Master and/or Slave
Fuel Lines
Also, the hose below with the frayed end was not connected to anything and I haven’t been able to figure out its purpose. What is this?
-Mike
Old 06-10-2023, 07:30 AM
Mike, you would be a life saver if you documented this in pictures. I am currently putting my puzzle together. Got an 87 Roller with everything stripped. The line you're asking about is the same in mine, but was one of the few things left in the engine bay.
I rebuilt my pedal cluster, so new master in there. And my G50.01 that I purchased was missing the speed ref sensor, slave was toast and a myriad of other parts (bought new slave, speed ref sensor, a few rubber seals, but lots to go.) ... so your post will be a needed guiding light for me and I'm sure others on here.
Luckily I have the release fork and clutch control shaft... everything else is coming out of my bank acct.
Also, what is CHT?
Thank you,
Ian
Old 06-10-2023, 07:57 AM
Also, what is CHT?
Thank you,
Ian
Ian-
CHT = Cylinder Head Temp Sensor
https://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
The Bentley, the 101 Projects book and a verrrrrry helpful friend/neighbor/forum member were key to the current and future state for me.
Right now everything is fully assembled but removed from the car so happy to snap pics along the way of anything specific to your project. Shoot me a PM with what is most helpful.
-Mike
Old 06-10-2023, 08:34 AM
Amazing. Thank you.
Old 06-10-2023, 08:47 AM
Small hose connects to a nipple on the airbox.
Old 06-10-2023, 09:26 AM
Any concern with the wear shown on the ring gear? It shows this consistent wear pattern in the same three spots around the gear.
-Mike
Old 06-13-2023, 09:46 AM
cmcfaul's Avatar
All the fuel lines in the engine compartment for sure.
Chris
Old 06-13-2023, 07:22 PM
Couple of quick follow up questions that got lost in the shuffle:
1. Ring gear above. Is this wear okay?
2. Starter, now with the image below. Thoughts on this wear and replacing?
3. Speed/Reference sensors: No current issues. Replace or leave?
151k miles.
Thanks for everyone's help/input.
-Mike
Old 06-14-2023, 10:40 AM
PCA Member since 1988
Run the ring gear, replace the starter gear. Or replace the whole starter proactively if it's old. If you go that route, consider the new lightweight starters too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-14-2023, 02:26 PM
Helpful; thank you.
Just to be sure, is the lightweight starter you're referring to the WOSPerformance version:
https://www.pelicanparts.com/More_Info/WSPLMS1102.htm?pn=WSP-LMS1102&fc=Y
-Mike
Old 06-14-2023, 02:51 PM
Yes, that's it. And for that price, I would just replace the whole starter.
Old 06-14-2023, 02:53 PM
