-   -   Newbie question: how do we check all cylinders are firing. (http://forums.pelicanparts.com/porsche-911-technical-forum/1141842-newbie-question-how-do-we-check-all-cylinders-firing.html)
Anjizkit 06-17-2023 10:01 AM
Have a 1987 911 targa. Everything is great but I was reading one of the builds where the owner figured out that one of his cylinders was not firing.
Question is. How do we figure that out? Do we like hear for knocking? Do we do the stethoscope methods? What do we do?
Apologies if it’s already discussed.
al lkosmal 06-17-2023 10:11 AM
Use your timing light by connecting to each spark plug wire, one at a time
targa72e 06-17-2023 11:54 AM
I have used a laser thermometer to check each exhaust pipe. If one is not firing (or firing at the wrong time because plug wires were mixed) you will see a lower temperature.
john
PeteKz 06-17-2023 01:57 PM
Why do you think they are not all firing?
Mike80911 06-17-2023 02:28 PM
You could also use a test light to ground each wire. Connect a test light to ground then stick the probe through the top of the wire where it goes into the cap. If the cylinder is firing the idle will drop.
pmax 06-17-2023 03:11 PM
A thermal scanner would be the perfect tool for this, hands off, no mucking with spark plugs etc.
Dr J 06-17-2023 03:34 PM
Get a squirt bottle that can send a stream rather than a mist and aim at each exhaust header, one at a time, noting how quickly the water evaporates. The one that does not evaporate quickly is the dead cylinder.
Flat6pac 06-17-2023 04:21 PM
+1 on DrJ. I use the windex spray bottle.
Bruce
Anjizkit 06-17-2023 08:55 PM
I am sure mine is great. The engine and smooth and pulls strong. But i was wondering how do we check this. So asked.
Anjizkit 06-17-2023 08:56 PM
Cool answers. Thank you. I learnt something new today.
dtxscott 06-18-2023 02:32 PM
Simply unplug each spark plug one at a time with the engine running. If the idle stumbles or changes, that cylinder is functioning
If the idle is unchanged when pulling the plug wire, that cylinder is no bueno.
mike sampsel 06-18-2023 04:28 PM
Originally Posted by al lkosmal (Post 12025346)
use your timing light by connecting to each spark plug wire, one at a time
+ 1
pampadori 06-19-2023 07:18 AM
How i do it:
I plug in my laptop to my ECM and open InfinityTuner software. While running, i deactivate each individual coil-on-plug one at a time to listen for the change in idle. Sometimes I deactivate each injector instead. :P
But same could be achieved by unconnecting each sparkplug wire one at a time.
Anjizkit 06-19-2023 11:31 AM
Am gonna learn what is a timing light now. [emoji3]
Superman 06-19-2023 05:16 PM
I strongly recommend against this. Experiencing 30,000 volts is an interesting experience. It teaches you to never touch the ignition system of a running engine.
The timing light method is a good one. As is the infrared thermometer method. Every tool box should have both these tools.
pmax 06-19-2023 06:42 PM
Along that vein, I was just about to mention the instant phase transition of water.
Superman 06-20-2023 06:57 AM
Yup. If you want to burn yourself really good with hot water, turn it to steam.
Fun Fact: Harkening to the days of steam shovels and other steam-powered equipment, the logo for the International Union of Operating Engineers is a steam pressure gauge with the needle pointing to 420. ;)
spoke 06-25-2023 04:05 PM
A follow up to the OP's question of how to find a cylinder which is missing. I had a similar experience where the engine would run fine then just start missing a bit. It would run good for a second then miss, good, miss. Or miss a lot.
Looks like the issue I had was the plug wire plug socket was cracked and maybe or maybe not making contact with the plug. Not sure how testing would find this.
BTW, these are Beru wires installed about 8 years ago. Almost every one was cracked and 2 just fell apart when slightly stressed. Which plug wires would you suggest to replace?
http://forums.pelicanparts.com/uploa...1687734024.jpg
al lkosmal 06-25-2023 06:32 PM
I have been using Clewett Engineering spark plug cables....they are very good/high quality
wrxnofx 06-26-2023 04:08 PM
Meh, I've done it plenty and not ever had an issue.
Curious about the timing light method. How does that method insure the cylinder is firing? All a timing light tells you is that there is an ignition pulse being sent down the wire. It's not actually telling you if the plug is firing. Similarly, it's not telling you if the injector is dead. Both of these are possibilities that a timing light won't show.
An IR thermometer/camera is probably best.
