PCA Member since 1988
Air reactor pipe plug came out of head
The heads on my engine are 1980 RoW SC heads that had plugs installed when the air reactor pipes were removed. A couple weeks ago I was doing a local PCA drive and the business end started getting noisy, like I blew out one exhaust gasket, and it was definitely on the drivers side.
Okay, maybe reusing the gaskets from the last time I took the heat exchanger off wasn't such a great idea...
So, I crawled under the car yesterday and pulled off the left heat exchanger and found that the gaskets were in good shape and didn't appear to be leaking. Then I noticed the the plug that was in the #3 exhaust port was missing. The plug is a M10x1.5, and I am on my way to Ace Hardware to find a same size plug or a short bolt to put back in.
How should I reinstall it so that it doesn't come loose again? Locktite? JB Weld? (no, I don't foresee ever removing it, in fact, I want to make damn sure it doesn't come back out). Lock washers? Star washers? Any/all of the above?
TIA
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-20-2023, 04:31 PM
10X1.0. 1/8" pipe plug pretty much.
206 637 4071
Old 06-20-2023, 05:31 PM
John thanks for the reply. I have an M10x1.5x20mm Allen head cap screw that I will use for now, which I will install with JB Weld. If that comes back out, I'll try the pipe thread plug, but that will require tapping the hole for pipe thread, and and because it's #3 head, the oil supply pipe is in the way. To re-tap the hole, I will need to remove the oil pipe, and that means draining the oil, yada, yada. That's what I hopefully won't have to do "next time."
Old 06-20-2023, 08:50 PM
No tapping needed. Just run it in until it's tight. Brass hex head 1/8" pipe plugs. I use them all the time, trust me. The thread pitch is perfect. No sealer.
206 637 4071
Old 06-20-2023, 09:53 PM
John, thanks again. I trust you. I'll go get one tomorrow, if I don't have one in my collection of brass pipe fittings. Brass, not iron?
Old 06-20-2023, 10:08 PM
The hex head is the important part, so you can get a good grip on it with a 1/4 drive socket. Allen or square head sucks. Either brass or iron will work, I just seem to find brass with the hex.
Of course we're assuming there are still threads in the hole. But it should still get a grip and tighten up, being it's tapered.
206 637 4071
Old 06-21-2023, 06:26 AM
