1988 3.2 Carrera, running on 5 cylinders
I finally got my car on the road! And its running on 5 cylinders. I made an appointment with my shop to look at it. Any quick and dirty guesses as to what it may be? Car is basically stock and was running increasingly rough before I put it away for the winter. I know this isn't much to go on but what the heck!
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Just watched a YT builder that had a similar issue after his entire build and turned out to be a loose sparkplug wire.
Ignition Air Gas Just have to make sure all three are getting to the cylinder. You could run the car and find the cylinder at fault by pulling a plugwire at a time then track down the above for the cylinder at fault. GL, keep us posted. |
Take a tiny hammer and repeatedly tap on the injector related to the dead hole. Pull plug wires off one at a time to find the culprit. Might work if it's just a stuck injector after sitting a long time.
PCA Member since 1988
When you find the dead cylinder, try swapping injectors to see if the problem follows the injector. If not, then try swapping spark plugs, and then wires.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It was the plug wires. Three wires were replaced due to corrosion on the ends that attach to the plugs. The others looked brand new. They checked the compression while it was there and it was great.
Congrats. And thanks for posting the resolution.
