G50 trans mod for T.O. brg fork shaft
Pelicans, found throw-out bearing fork shaft badly gauled during clutch project on 88 SC
Trans must be machined for needle bearings to accomodate updated fork shaft, since original shaft NLA. Porsche tool 000 721 929 20 consisting of jig and reamer/drill a month away and $600. Anyone have a tool rental program, know a shop that performs mod, or have a viable work-around for this? Any help greatly appreciated! Duffy 911 '71 911T |
Senior Member
You can get the Rausch & Spiegel fork shaft - it has insert bronze bushings, bypassing modifying the case. Just installed during full clutch build in April - work great.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
gearhead
CMS can do it for you.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Don't bore out the holes! The design is already weak enough.
Fork shaft/kit
Thanks Pelicans for the speedy replies. Found the kit right here on Pelican Parts.
#10-1518-090-M157 by Rausch & Spiegel |
