78sc fuel pump wires routing?
Guys,Is this the correct routing for the fuel pump wires?
Old 06-21-2023, 10:48 AM
Mine runs to the left side between tub and tank, has a bendable tab to hold it, then pops up to the fuse block near the filler neck. Nothing special.
Old 06-21-2023, 01:52 PM
Earthling
Brian Cameron's Avatar
The wire hold-down tab circled in yellow is meant to secure the fuel pump harness out of the way, and as noted the harness wire then makes its way around the bodywork gusset to the relay in the fuse box.
It looks like the hold-down tab is missing its protective plastic coating (or maybe it was painted over?). If so you’ll want to slip some heat shrink tubing over the tab as a replacement. You don’t want that metal tab eventually slicing into the wiring harness with road vibration.
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 06-22-2023, 10:04 PM
