Unknown noise from frunk
Hello
I could not avoid a large pot hole the other day, and now when I start the engine it is accompanied by a buzzing from inside the frunk. This is my first ('82 Targa) Porsche, I have a lot to learn. Any input will be gratefully received.
Old 06-27-2023, 08:34 AM
Look under the car and see if plate covering fuel pump is bent. Fuel pump may have been loosened by the shock also. Between front wheels.
Old 06-27-2023, 08:38 AM
PCA Member since 1988
If it's high in the frunk, could be the blower fan got misaligned.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-28-2023, 12:41 AM
