What are these parts?
Assume something from my A/C when I decommissioned it…
it was in the front smugglers box holding the a/c unit in place,brackets and a clip
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Wow, no waiting with this one - thanks professor!!
How about this one?
Sent from a device using an app.
Last edited by TwoBluPorsches; 07-02-2023 at 05:15 PM.. Reason: Edit, my first guess was wrong It’s probably 911 126 124 01 |
PCA Member since 1988
Those look like the straps that support the front suspension crossmember to the floor
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
this one is for the A/C compr.bracket..bolts on the the engine case right next to the oil pressure sending unit
Ivan
That's what that's for? I guess that makes sense now that I've had one on my engine. Somebody must have changed out the bracketry when changing from OEM to aftermarket compressor and left the stupid thing on.
1982 911SC |
