Simple question- 3.2 brake lines
Porsche Stainless Steel Brake Line Kit from Pelican.
Long lines go to the front, shorter one to the rear? I ask this because the old front lines are not the same in length of the replacement Part is https://www.pelicanparts.com/More_Info/PEL911SSDOT1.htm?pn=PEL911-SSDOT1 http://forums.pelicanparts.com/uploa...1687674753.png Thanks! think the longer one in the front, just wish to be sure! |
The reason for this configuration is that the front brakes usually require longer lines due to their positioning in relation to the brake master cylinder and the suspension components. The rear brakes, being closer to the master cylinder, typically require shorter lines. However, it's always important to refer to the specific instructions and documentation provided by the manufacturer or supplier of the brake line kit to ensure the correct installation. They will provide detailed guidance on the installation process and the proper routing of the brake lines for your specific Porsche model. MyAARPMedicare Register
Your AI bot is not ready for prime time.
| All times are GMT -8. The time now is 11:06 AM. |
