Safari-look suspension
If you're keeping the torsion bars, I get that you drop the spindles on the front struts, but what do you do to the rears? Just re-index the spring plate? Do you need to buy a longer shock?
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 06-27-2023, 05:46 AM
Dropping the spindles will lower the car.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 06-27-2023, 06:50 AM
Bah. Terminology. Lowering the spindles on the strut will lift the car. Somehow it became common vernacular to change "raise the spindle on the strut to drop the car" to "drop spindle"... Despite it not actually dropping the spindle, but doing the opposite.
Old 06-27-2023, 07:02 AM
Cory M's Avatar
Yes. Longer shocks and reindexed torsion bars (or coilovers). You may be able to get the lift with a stock shock, but you won't have much travel left for droop.
Old 06-27-2023, 09:52 AM
