Engine Builders in PNW (Portland)
There are a few engine builders I know here. Including some excellent guys if cost doesn’t matter - but prices seem to be particularly high in the Portland area. Looking for some options that might operate more in the Goldilocks space of price and expertise.
I may still do this myself but just found out a new baby is on the way so if I can find a good option I just may pay someone. Recent leak down numbers are all 90+ and the oil pressures are excellent but it’s starting to burn a lot of oil and has 100k miles so I’m suspecting it’s top end time. I can pull the engine and drive a few hours if that expands my options. |
What are the real leak down numbers?
How is compression? Can you please quantify how much oil you're burning? I wouldn't expect a 3.2 to be ready for rebuilt at 100k miles if treated properly... I don't have first-hand knowledge of "lower-cost" engine rebuilders in the area. (I rebuilt mine myself but did have others do the machine work.) Those rebuilders that I do know command higher prices and for good reason. I would start with Rothsport just to get an estimate. Last edited by fanaudical; 07-07-2023 at 09:18 PM.. |
Valve guides? Exhaust look Like this? My car at 3-400 miles per quart.
![]() If not, not time yet.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 07-07-2023 at 10:14 PM.. |
Marque Motors Matrix Heckmann Thiemann A&P Rothsport
I’ve had the car for 8 years or so, It was already at 500 miles or so per qt when i got it at 60k miles. 8 Years and 40k miles feels fair enough for some R&R. Fairly certain it’s time, just looking for engine builder recs. Not looking to pay 20k.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
The 9 Store
You won’t find an engine builder doing an entire rebuild for less than 20k.
All used parts sold as is. |
Eh, they’re around. Just not close to here.
If my guess at the scope is correct, you will be under $15k but most likely over $10k.
Seems like I have a winter/spring project. At least I have a garage heater!
I'm local to the OP. Rothsports isn't taking new work to my knowledge as of a month ago. I've got an Oct. appointment at AnR. H&T had a changing of the 'guard' and are months out as well. Personally I would consider crating it and ship to CA. I've got two numbers around Carmel and others will have SoCal suggestions. One of the two Carmel #'s is semi-retired but did my motor.
Congrats on the incoming new addition. |
FWIW, for jobs like this, I prefer to find a guy who has already done this work many times. Why? Because while the physical work is fairly straight forward and there is lots of help, how do you know if what you are looking at is ok to reuse or recondition vs buying new. How do you ensure the new part is good to go? You cannot read about this. This is the secret sauce the pro-builder offers.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 07-08-2023 at 10:23 AM.. |
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 Last edited by kyngfish; 07-08-2023 at 12:07 PM.. |
gearhead
He moved out of town and bought a place with a small shop on the property. He’s still taking work last I knew.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I will have to make a call tomorrow to see if I need permission to DM a number. The other one I'll have to call a friend to get that shop number. He moved from Napa and that is the shop he uses.
We are planning on PIR 7/16. White 67 if you make it. |
I’m out of town! But thanks for the heads up. Catching some rays before the awful PNW winter and a newborn puts me on lockdown.
PCA Member since 1988
Hands down: Dick Elverud in Hillsboro. His business name is Northwest Machine Products. He's both a Porsche engine builder and master machinist. Phone is 503-502-1609. He did the machine work on my heads crank and rods for the engine I built. He's close to 90 years old, so I don't know if he has retired in the past few months. Last time I talked to him was about 3 months ago.
Otherwise, there are several good builders in the Seattle area, including John Walker, who participates frequently in this forum, and whom others mentioned. I'd much prefer to deliver my engine project to Seattle than to crate it and ship it to California.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
