964 G64 Transaxles - Ins and Outs
Hey everyone!
I'm trying to educate myself on early first gen G64 transaxles. I didn't see a lot of discussions on here, outside of converting to C2 configurations for RWD. Not much info on stock configurations, gearing, LSD, etc. I'm interested in the early 964 models, G64.00 type, and if there's anything specific to be on the lookout for when purchasing one. Are their failure points that are typical? Standard service items that are guaranteed right out of the box? LSD upgrades, if not stock? Anyone go through one themselves? I'll be in the market soon, and I just don't want to fly blind and pickup something that's been sitting in the back of a Ford Pinto wagon for 21 years as a "ran fine when I pulled it", only to find out that every one of these had prefamulated amulite issues and the noble trunions always jammed up with the panametric fam, if left to sit too long. ![]() Thanks for any help! 915 transaxles are about my knowledge limit, and even that is pretty sad. So any pointers or recommendations would be helpful. |
They're pretty robust The LSD is variable, controlled by the ECU
Eventually they'll need synchro etc standard G50 stuff Need a number of special tools to work on them
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
PRO Motorsports
They use small 100mm output flanges. I would ditch the ABD differential and use an LSD with 108mm drive flanges
Other issue is lack of aftermarket gears. They’re different than G50 gears. Not a problem if your keeping them stock. |
Good info and good to know! Thanks!
I would be keeping it stock, but I was curious if the G64.0x was only offered with one gearing option from the factory. I didn't see anything else listed, number-wise, that would suggest it was offered in any other gearing configs. I think the only "improvements" I would consider making might be anything to help with control or robustness at the time of rebuild. Did you mean AWD? If not, what is ABD? Sorry, not familiar with that. Thanks! |
gearhead
Read this thread. You’ll find it very informative and useful.
https://forums.pelicanparts.com/porsche-911-technical-forum/1132550-c4-awd-drivelines.html
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
gearhead
Nope. Didn’t even look. Though it leaves me wondering why he didn’t just bump it…
Yep! That's me!
That was the fact finding thread that led me to starting this, and what will lead to a build thread that will ultimately lead me to needing therapy.Quote:
Hope I'm not being too repetitive. Just wanted to get pretty specific. Probably going to be a short thread. Last edited by scootermcrad; 02-27-2023 at 12:17 PM.. |
gearhead
There's very little you can do to modify or upgrade a g64.00 for performance. While the synchros are G50 based, most everything else about it is unique to it. There's no special ratio gears or final drives available. What you get is what you get.
The good news is, I think the questions have been pretty well answered already. All the G64.00 transaxles seem to all be basically the same. I'm totally good with that. In fact, NOT doing a bunch of upgrades sorta makes me happy, in this particular situation. I can turn my focus (and budget) to other parts of the project. Although... you just made me think of a couple other questions. Shifters and instrumentation. I'm assuming any aftermarket shifter that works for the G50 will work, (WEVO, etc.). I'll deal with instrumentation later, though. EDIT: Looks like the shifter kits are very different. I guess that makes sense. Not much available. Looking like the Sleepwalkers kit might be the best bet. Last edited by scootermcrad; 02-27-2023 at 02:34 PM.. |
lake wales fla
As far as installing a LSD in a G64 I think it can be done but again IIRC takes a lot of mods. |
Yeah, most likely, I won't be opting for any major modifications beyond stock spec. I read through a couple rebuild/refresh threads and found that these G64 transmissions seem to hold secrets about their condition, specifically the AWD clutch packs, until you open them up. So it is probably best that I would consider any purchase to be of "core value" unless it has known history before removal. Looks like a rebuild, even if attempting myself, could get expensive pretty fast, if there is any major issues. I hope I'm wrong about that finding, though. Either way, I think for my purposes, stock configuration will be fine and I would make sure it's complimented with a nice flywheel and clutch assembly, and a nice shift kit. |
lake wales fla
The 9 Store
I have this one for sale if you are looking to purchase.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1129269-rebuilt-g50-trans-w-lsd.html
All used parts sold as is. |
Not sure of the accuracy but here are the ratios
https://californiamotorsports.net/pages/porsche-g50-5-speed-transaxle-specifications |
