Dept store Quartermaster
lendaddy's Avatar
Still need this part, anyone?
This is the "hot air line" for the drivers side exchanger, it is item #19 in the illustration. Thanks guys!
Cornpoppin' Pony Soldier
Old 06-10-2003, 06:25 AM
lendaddy's Avatar
Sorry, gotta bump. Starting to get a little worried about this one. Parts Heaven, NO. OK Foriegn, NO. Any other ideas? Thanks
Old 06-10-2003, 08:21 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Maybe try a flexible metal line?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 06-10-2003, 08:26 AM
lendaddy's Avatar
No chance on the flex line, it is a VERY tight bend and it passes right over (maybe touches) the heat exchanger. Hmmm
Old 06-10-2003, 08:38 AM
Limbo
Slider79SC's Avatar
Why not just buy a mandrel bent piece of exhaust tubing in the correct size and cut and fabricate it to fit? We have done this for some custom intercooler pipes and it works well, and for very little money.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 06-10-2003, 08:58 AM
lendaddy's Avatar
You may have an idea there but I dont think so. This thing bends right back on top of itself. I believe it is clamshell manufactured as mandrel bending cannot produce a 180 degree bend with such a tight centerline radius on 2.5" material. Worth a look though, thanks.
Old 06-10-2003, 09:01 AM
Autodidactic user
David E. Clark's Avatar
I second Slider's recommendation. "Hot-Rod" shops do this kind of work all the time. Give your local shop a call, I'm sure they can fix you up -- and for a lot less than a Porsche repair shop!!
'73 911E
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 06-10-2003, 09:04 AM
MN
Sarah's Avatar
You know...we have a box of stuff in our garage from previous owners and I think we might have that part. I don't know if it is the right one and/or in good enough condition for yours but i'll check and take a digital for you.
87 930 Blk/Blk
Old 06-10-2003, 09:09 AM
Limbo
Slider79SC's Avatar
To remedy the super tight bend, what I have done in the past is buy the tightest mandrel bend I could order (usually from a street rod shop) and then section the radius and weld the two pieces back together. It makes a super tight bend and usually doesn't look too bad either.
Here is an example showing the section to be cut out.
Old 06-10-2003, 09:10 AM
lendaddy's Avatar
Thanks sarah, you have a PM. Slider, good idea! One thing though, I don't know your location but I am assuming Cali or close. You guys are so lucky, you use phrases like "local Hot Rod shop". What is that? All I have here in west Michigan is my local PepBoys! UGGhhh
Old 06-10-2003, 09:57 AM
Limbo
Slider79SC's Avatar
lendaddy,
I live in Colorado and it is nice to be able to go to my local shop during my lunch break. It's funny how much I take for granted living close to a large city and to be able to get things so quickly.
If you need a piece of pipe try www.summitracing.com. They carry the same stuff that I get locally. If not let me know what you need and I could get it for you and ship it out.
Old 06-10-2003, 10:16 AM
Slant930's Avatar
I know I have one of these, let me know if you are still in need.
Tim
1983 930 w/ goodies
Old 06-10-2003, 02:48 PM
lendaddy's Avatar
Timothy, You have a PM. Thanks! This board is amazing!
Old 06-11-2003, 05:44 AM
