Can't open door from outside
Hello
After restoring the door I can't open the it from the outside. From inside is no problem. See pictures, one with door handle pressed and one without. ![]()
looking at it ..one q i have.... was it opening before the work?
The door mech.fork look bend inwards..therefore it does not reach far enough to open with the shaft from the door handle..another thing i see ..there is no lubrication on it at all ..all looks dry Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thank you Ivan, that makes sense.
The fork must have been bent at some point because it was okay before. Will traighten and grease it up. I was just rubbing it with lock oil. Cheers! |
one more idea ..have you tried to close the door lock manually(with your hand)- 2 clicks and than using the door handle to release the door look?
Ivan
I've used a cam timing pin and drilled out the threads in order to slip it onto the door handle pin, which makes it longer.
On my 3 2 there's adjustment on the rod on the exterior handle. If you take the exterior handle off, the trigger engages with a threaded rectangular nut. Turning the nut makes the rod extend more or less. All of this is in the removable exterior handle assembly
Sent from my SM-G988B using Tapatalk |
The car was in the body shop and probably little filler and paint on the door side made the handle come out a millimeter. Also the new gasket might ad a millimeter. Can't see any adjustments for the pin. But I've done some small adjustments to the fork and think I'm getting there. The car has many miles and metal contact surfaces rub down with time I guess |
They could not close the door properly..only after i have found out somebody have used door handle from later model on theirs where the pin is much longer....had to cut 3mm on the end off....that might be something to look for -pin from later model door handle. Let me look to show you the difference...
here ..
Problem solved
I took both lock assemblies to the vice and bent them straight just a few degrees. Also put some grease. Now they open perfectly |
super;-))))
