911 SC AC rotolock o ring question
Ive had my 911 for 14 years, and despite living in Houston, TX have never put any time into getting my a/c going. Now that Im older and wiser Id like to experience driving the car year round in comfort
Before taking the system fully apart I was surprised to find it holds a vacuum very well. I believe part of my issue is sealing the rotolock bolt-on flanges on the back of the A/C compressor. Also fair to assume I may have some leakage through the hoses which all look to be fairly original to the car. No drastic leaks fro what I can tell.
A couple of questions:
-Does this roto-lock assembly have any other seals besides the square cut o-ring that fits in the groove pictured? Ive seen various other rotolock assemblies with Teflon o rings, and a gasket to seal the entire rotolock assembly to the flange.
-Assuming this o ring is all that's needed, any good sources for this square cut o ring or does anyone have dimensions? I can measure the groove but assume there is some clearance required in there for the ring to compress once tightened up.
As a note, a Griffiths full system is on my wish list, but want to try to at least get the current system going at the moment. Thanks for any help and insight!
1980 911 SC Targa
Old 07-11-2023, 08:26 PM
