Dead —- High-Lift-Jack
Any one recognizes the maker of this jack?
IIRC, I bought this when I was learning how to do my first engine drop. And I believe a few members have (had) this unit.
The hydraulic line busted and I need to order the part. However, I can’t seem to find the maker. Yes, I have checked unit but there are no markings. I have searched EBay looking for a similar unit but so far no luck.
FYI, the line is plastic. Maybe I should get a braided stainless steel line made? Or should I bite the bullet a buy a new one?
Thank you.
[img]
Old 08-28-2021, 07:49 PM
Take the line to a hydraulic hose shop. They should be able to make up a line for you.
Old 08-28-2021, 07:59 PM
It's a 914 ...
stownsen914's Avatar
Yep, or a supplier like McMaster Carr. They probably stock every imaginable size.
Old 08-28-2021, 08:01 PM
pete3799's Avatar
This.
If it's a seal that's leaking i had good luck on this site finding what i needed to rebuild my 2 ton long reach jack.
https://www.hcrcnow.com/shop/seal-kits
Pete
79 911SC RoW
Old 08-28-2021, 08:07 PM
The plastic tubing is definitely the issue. It burst (see bottom right hand corner).
I still wonder why this is plastic. I would have thought it should have been a metal line/pipe.
Old 08-29-2021, 01:19 AM
pete3799's Avatar
That looks like an air line fitting.
What does the other end attach to.
Pete
79 911SC RoW
Old 08-29-2021, 06:26 AM
I think Pete's right That looks like truck air brake line which is an odd choice for that application
I'd remove the fittings and line and take it to a hydraulic shop it looks like standard fittings
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 08-29-2021, 08:49 AM
Northern Motorhead
wildcat077's Avatar
Worst case , get in touch with Len Cummings ( Boxster GT ) he can basically make lines for anything.
He made a whole bunch of stuff for me when i swapped a 3.6 in my car and his work is outstanding !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-29-2021, 09:28 AM
FYI, one end is 13mm and the other end is 14mm
Old 08-29-2021, 01:05 PM
I tried researching why this has that line and my other 3 jacks don’t have it. Though so far I couldn’t find any engineering info, I suspect it’s because of it long length.
If I were to go to an hydraulic place, I wonder if there are issues with braided line or an actual metal pipe/line vs buying another similar plastic line????
Old 08-29-2021, 01:14 PM
This puppy measures 22”. For reference, I bought this unit many moons ago after having seen Pelican Members using the same jack for its high-lift feature.
Old 08-29-2021, 01:19 PM
Slippery Slope Victim
NY65912's Avatar
That Jack looks like a red version of my blue AC jack.
Mike˛
1985 M491
Old 08-29-2021, 01:32 PM
Mike,
Do you have a pic? Google showed me nothing. Thanks.
All,
I think I will stick with the plastic replacement. Why? $30.00 (plastic) vs $200.00+ for SS/Aluminum is the decision maker. 😂
Old 08-29-2021, 02:54 PM
NY65912's Avatar
https://www.ac-hydraulic.dk/us/products/hydraulic-jacks/dk20hlq/
Mike˛
1985 M491
Old 08-30-2021, 04:39 AM
Thanks Mike.
Mine must be the only predecessor.
Old 08-30-2021, 02:31 PM
Ventura HoseMan helped me out.
I was told that the blue tubing is better than my original black one.
All fixed. Thank you all.
Old 08-30-2021, 02:34 PM
I see you're in Agoura. Try:
Hoseman
3500 Camino Avenue
Oxnard, CA 93030
(805) 988-1072
You can see him from the 101 freeway. Take your offending hose/pipe. Lay it on the counter. Your new piece will appear on the counter in about 10 minutes.
Old 08-30-2021, 09:55 PM
Hoseman
3500 Camino Avenue
Oxnard, CA 93030
(805) 988-1072
Yeah, that’s where I went (Ventura Hose Man)
Old 08-30-2021, 10:00 PM
Antonov's Avatar
Thread back up....
As luck would have it, before the start of big project, the oil line on my AC Hydraulics DK13-HLQ floor jack burst.
It looked like a Swagelok fitting, but it's a very fine thread b-nut with a compression fitting that I'm not familiar with.
Does anyone have info on a replacement line?
Thanks in advance.
p.s. I love my ac floor jack but wtf, why make a line out material so bridle, it came apart in my hands.
(kg/lb)
Old 05-25-2024, 01:43 PM
