Rtrorkt's Avatar
Frunk Hood Hinge Question
Have installed a locking hood strut on the left side of the hood. I think my local shop tried to close the hood without releasing the strut lock. Appears to have bent the hinge. Can the hinge be adjusted, assuming the bend is not too bad, or is a new hinge needed?
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 07-08-2023, 08:57 AM
Rtrorkt's Avatar
Figured the issue. Cautionary tale, I have the Rennliine locking strut on one side, left, and someone at the shop tried to force the hood closed that bent the hinge. Am sourcing another hinge from a fellow Pelican. is it easy enough to take the old hinge off with the strut in place and install the new one? Or does the hood need to be removed completely?
Old 07-10-2023, 07:26 AM
cycling has-been
bkreigsr's Avatar
no need to remove the hood
Old 07-10-2023, 11:01 AM
Warren Hall Student
Bobboloo's Avatar
DO NOT remove a hinge with a gas charged strut in place. The strut will force the hinge into the cowel and bend your cowel. I don't know what strut you have but if it's gas charged don't loosen the hinge bolts. Hinge and hood alignment is done with the struts removed. The struts are the last step.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 07-11-2023, 08:34 AM
