G50 pedal cluster roll pin
What is the difference between the clutch pedal roll pin for an ‘88 G50, (N023 351 1), and the previous model, cable clutch, roll pin, (90030900200). I have measured the old ones from my pedal cluster and they are 6x28mm which is the same size as the older roll pin.
1988 911 Guards Red Carrera Coupe 2002 Silver Boxster (Wife's) 1988 911 Guards Red Carrera Coupe(sold) |
Looks like about $1.50 each on PP.
I just did this on my build. ![]() ![]() This is a pedal cluster on an 87. I purchased N023-351-1-OEM, fit perfect. -Ian |
Specifically here are the parts I replaced.
The rest was salvageable. I did get the pedals and the actual mount powder coated.
