torqueing sc crank pulley nut
any one know if theres a special tool to hold the crank /balancer pulley while torqueing the bolt to 100+ lbs. the pully has no holes or anything to hold it. 79sc 3.0l . i m thinkin air impact to get it off. i was reading old forums that cautioned against using flywheel lock because the crank will distort so minor that it creates a vibration. i f thats the case there has to be a tool , im guessing i can make one w a v belt . appreciate any input. thnx
Old 12-12-2024, 03:57 PM
PCA Member since 1988
The crank will not distort. That sucker is way thicker and stronger than the wrench you use to apply torque to the nut.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-12-2024, 11:55 PM
I was torquing Durloc pulley bolts on performance engines to 150 ft lbs. Tool, I think was originally used for power steering sprocket on 964. Sometimes pulley holes need to be tuned up a little to fit.
Old 12-13-2024, 11:20 AM
i wish there were holes like that in the pulley
Old 12-14-2024, 09:09 AM
Are you running AC ?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-14-2024, 09:14 AM
Well the pulley couldn't handle that much torque without deforming. Is the trans off? Just use a wrench like this;
Old 12-14-2024, 09:16 AM
Alan L's Avatar
I never torque mine. Just do it up 'tight'. Never had an issue in 20+ yrs - on road and track. I seriously doubt I am anywhere near 50+ ft/lbs. I use the pulley tool.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-14-2024, 10:28 PM
so nobody out there has heard anything about tweakin the crank? i m new to these engines but work on a lot small eng stuff dont ever wanna put load where it doesnt need to be cause they re delicate. first thing i thought was flywheel stay( block of wood between the pressure plate bolt n eng yoke) , but as usual i overthought and looked it up n sure as s#$t there all kinds of forums claiming lots of guru 6 builders caution about runnin tension thru the crank like that. not giving details about type of crank or how much torque but makes me want more input. thnx for input everybody
Old 12-15-2024, 11:48 AM
You must be looking at Fakebook or Reddit groups. They are wrong.
I won't trot out the math here, so just consider this: The force the piston puts down on the crank pins is TONS. Yeah, thousands of pounds. That's WAY more torque than you can get on the nut on the end of the crank using whatever wrenches/wedges/locks you can lay your hands on. And the pistons hit the crank with that force thousands of times a minute, for thousands of hours. The cranks don't twist.
Capische?
Old 12-15-2024, 04:08 PM
ok pete i found one of the posts
Old 12-15-2024, 04:58 PM
ok pete i found one of the postshttp://forums.pelicanparts.com/uploads26/IMG_06541734310870.png
Old 12-15-2024, 05:04 PM
tech difflty
Old 12-15-2024, 05:05 PM
Old 12-15-2024, 05:12 PM
Old 12-15-2024, 05:22 PM
Old 12-15-2024, 05:25 PM
Alan L's Avatar
How do you think the crank survives the flywheel bolts being torqued.?
Then there is the ring gear lock for undoing tough nuts and flywheel bolts.
Not to mention what Pete Kz has mentioned.
You are over thinking it. 100%
Alan
Old 12-15-2024, 11:46 PM
That post from Red Rooster is wrong too.
Old 12-16-2024, 01:04 AM
But years ago he knew a guy?
Old 12-16-2024, 06:28 AM
dpmulvan , no not gonna run ac
Old 12-16-2024, 09:06 AM
alan , theres no twisting force through the length of the crank when doing flywheel bolts
Old 12-16-2024, 09:09 AM
