Priming the MFI...?
Our 911E is ready for starting after many years,
When the key is turned on, it takes just a second or two for fuel to reach the injection pump....but cranking the engine for a few seconds doesn't produce any fuel at the injectors.....despite the fact that the injection pump was recently professionally rebuilt. Does it take a bit for it to get primed? Per |
Just for the sake of Archiving,
Yes it does. I took me about 15 minutes of cranking, but you can take a big rubber band and a drill to prime it. (Thanks Tyson) |
Thanks!
Thanks again,
I did a search on MFI and couldn't find it, must not have been looking hard enough. I'm a little nervous about cranking so long as the car has already stripped one flywheel... Per |
hmm... I'd say try the rubber band trick with that iffy starter (it did get fixed though didn't it?)
The trick is first mentioned under this thread from when I started my car. http://forums.pelicanparts.com/showthread.php?s=&threadid=103911&highlight=She+ru ns |
| All times are GMT -8. The time now is 04:54 AM. |
