Idle on my 3.2 stays high at a light
When I come to a stop light the idle will go high to 1000. Then after a bit it will drop down to correct idle. Sometimes even I can kick the peddle and it will drop down a bit. Idle set correctly with wire at B and C. I lightly sprayed the linkage .idle control valve is new Did the same on old idle control valve . What do you all think ?
Old 07-14-2023, 07:00 PM
Senior Member
Check the set screw on the idle stop setting, and also the cruise control cable can hang up during throttle return.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 07-14-2023, 07:34 PM
Thanks ! Will check tomorrow!
Old 07-14-2023, 10:40 PM
proporsche's Avatar
also check your micro switch and throttle position..with the engine off..push on the throttle a little and you should be able to hear the click on the switch ..on the pic the top one
1985 911 with original 502 191 miles...808 198 km
Old 07-14-2023, 11:23 PM
Had same issue for a while, in particular when engine and trans were warm and it was due to the linkage binding where it is hinged on the side of gearbox. Check this and lube.
One check you can do is when you are at a stop light and the idle is too high, try to reach behind the accelerator pedal and pull towards you to see if that makes the idle drop to normal rpm. If so, this is the linkage related issue.
Old 07-15-2023, 02:48 AM
Thanks all for this ! I will try after the stupid heatwave in Fallbrook!!
Old 07-15-2023, 08:59 AM
So I went out and listened for the click in the micro switch. Did not hear. Put in my hearing aids did not hear. Then I sprayed the whole area with contact cleaner and then sprayed it again. I heard the click !!! Car ran well on my test trip and idle stayed correct for my whole trip. But ! When I piled into the garage it was up a bit to 1000. I had the AC on for the last half of the tip. Maybe I need to adjust the base idle down just a bit more.
Old 07-15-2023, 10:47 AM
From what I have been reading , I don’t think I’m going to worry about 1000 rpm’’s after a good drive. Idle is so much better .
Old 07-15-2023, 10:57 AM
Had to fiddle with my pedal to get idle to drop.
Something to check on that will cause the throttle rod to bind up on clutch cable when these two nylon bushings deteriorate after 40 yrs…..(they have better bronze replacements too at PP)
Old 07-15-2023, 11:46 AM
Thank you .
Old 07-15-2023, 11:53 AM
proporsche's Avatar
sounds like you got it;-) just turn the idle 1/3 in and you`ll be fine
Ivan
Old 07-15-2023, 01:59 PM
