Part Number Help
Hi,
Could someone please give me the part # for the small 930 air hose that goes from the passenger side of the intercooler to the the AAR? It's maybe 8 to 10" long with a bend in the middle. It's not entirely clear form the PET and the dealer was unable to come up with the part number. Thanks very much! |
What year 930? Mid 70's or late 80's?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Mid 70's Item 48? 930 110 109 00
Late 80s. I spoke w/ the dealer again and he thinks it's now a longer hose that has to be cut to size. The original hose has a permanent bend to get around the AAR. When you cut a longer straight hose to size, it kinks slightly, which is what I've got going on now.
Anyone able to solve this mystery?
lake wales fla
Not really a mystery, you just have to have knowledge of the older cars which the dealers definitely do not.
If your car is a 86-89 US spec 930.68 it takes a 930 110 334 03 molded hose. If it is a 78-89 EURO spec 930.66 it takes a 999 239 009 40 which is sold by the meter and cut to fit. The actual hose size would be 18 x26 x180 mm The hose in my pic is for 86-89 US spec 930.68 Richard
That's exactly it. thanks for your help, Richard. Much appreciated.
![]() If you cannot get the correct hose, a spring inside that straight hose will help prevent the kink. Len
