r_towle's Avatar
Fuel pressure
1984 3.2 Carrera
When does the pump build pressure at start time?
Turn key on, does pump run and build pressure?
Or
Turn key to start, pump runs and builds pressure?
I’m hunting what I’m hoping is just a dirty system.
My fuel sender gauge is no longer going all the way down.
I’m replacing
Fuel strainer screen
Fuel filter
Fuel level sender.
I’m wondering if I should replace the 40 year old fuel pump while I happen to have the fuel tank drained.
Old 07-19-2023, 05:33 PM
PCA Member since 1988
Re gauge not going all the way down: Probably just crud in the sender. Does the Fuel Low light come on?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-19-2023, 09:01 PM
r_towle's Avatar
It did come on….but I’m not certain it goes down that low anymore. I bought a new one.
Old 07-19-2023, 09:09 PM
Pump starts running only when cranking.
Gilles
RoW 88 Carrera coupé
Old 07-20-2023, 12:52 AM
r_towle's Avatar
Thank you.
I’m hopeful it’s just screen and filter and sender. I might need a check valve….and fuel lines, we shall see tomorrow.
Old 07-20-2023, 05:09 PM
