side mirror replacement
How exactly do you remove the side mirror on a LWB 911 (1970)? I currently have a Talbot 333 mirror installed.
thanks, Rob |
PCA Member since 1988
On the inside of the door frame there are two rubber plugs exactly under the mirror bracket. Remove those and there are two Allen screws underneath. Be careful not to drop them inside the door, or you will have to fish after them or take the door panel off.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
hmm...i dont see any allen screws. All I see is the J-hook bar from the mirror.
figured it out...you have to take the mirror apart while on the car.
I guess it's different than mine.
