-   -   FP Gauge Working or Not? (http://forums.pelicanparts.com/porsche-911-technical-forum/1143776-fp-gauge-working-not.html)
Funracer 07-26-2023 08:44 AM
Yesterday I checked my system pressure by jumpering the FP and closing the valve on the pressure test setup. In this picture its open but you can see how its attached:
http://forums.pelicanparts.com/uploa...1690385681.jpg
71 PSI which is mid spec.
Then removed the jumper wire and without thinking started the car again. Started immediately and rpm jumping around a somewhat. Then realized I had not opened the FP gauge valve. It was closed and the car was running.
Today I repeated this by opening the valve and starting car then took it for a drive everything was normal. When I got home left the engine running and shut the valve again. Engine kept running with wavering idle for a couple of minutes before I shut it off.
I was thinking in the past I had done this once (closed the valve with engine running) and the engine shut off immediately.
This is not a Harbor Freight FP tester. What gives? Or is this normal?
PeteKz 07-26-2023 01:33 PM
Yours is a Lambda-CIS right?
If it's warmed up, it usually will keep running. It may not run well and will be hard to start like that.
Funracer 07-26-2023 02:05 PM
OK that is actually good news.
