-   -   5-pin multi-function relay(chinese) malfunction (http://forums.pelicanparts.com/porsche-911-technical-forum/1144016-5-pin-multi-function-relay-chinese-malfunction.html)
Atlracer 07-30-2023 06:11 PM
Crazy, took me some time to figure out and self diagnose this...
At operating temperature my car started to shut off randomly while driving (an documented) issue on the web .
Upon cranking the car back "on" noticed the fuel pump wasn't "turning" eventually it did so i made it home but it happened repeatedly and finally i went to check Fuses ,Relays
and noticed the China 5 pin relay was extremely hot causing the relay to stop working when at temperature . i just switched to the original one that was at the lower Ac location Tested it at temperature and its all working properly , No self shut off nor Relay malfunction all normal.
CHINA 5-PIN MULTI-FUNCTION RELAY BEWARE !!!
proporsche 07-31-2023 02:08 AM
yup, as you found out....nobody in the right mind would put these relays in their 911....
Ivan
