Door Hinge Bolt alternative
I'm interested to see if anyone has a suitable alternative to the shallow head triple square door hinge bolts? I'm not worried about keeping things original, so I'd like to find a shallow socket or button head that would clear the door and be less susceptible to stripping out.
Old 08-01-2023, 06:41 AM
Do you mean door latch bolts??
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 08-01-2023, 06:49 AM
Keep the triple square and get a triple-square driver set. From what I understand they're better for delivering torque and less likely to strip than other bolt heads, especially with a shallow head.
1982 911SC
Old 08-01-2023, 06:54 AM
I actually have a triple square driver set, but had one on each side that was stripped. Similarly, I had one of the striker bolts stripped as well.
Old 08-01-2023, 06:59 AM
I guess someone tried to jam a torx in there at some point. I actually really like the triple-squares, kind of wish they were used more frequently.
1982 911SC
Old 08-01-2023, 07:51 AM
Just use a standard 8 x 1.25 hex head bolt. Porsche did.
Old 08-01-2023, 11:59 AM
