Engine bay light - idiocy
I’m having some trouble with the wiring on my engine bay light for my ‘84 911 Carrera, it’s just not making sense to me. I replaced the rear lid which included an engine light. After researching the wiring and Bentley, it seems my car’s PO removed the original light. I do not have/ can’t find a harness or other connector for the light and am simply trying to hardwire the light in so that it will turn on as it should, with the slider on the switch itself.
Bentley doesn’t show (or I can’t find it) the wiring diagram for the engine bay light but I’ve searched and found some other posts indicating the brown wire goes to a ground location (MPXI) and the gray wire is connected to the taillight assembly (58). I’m presuming the connection to the taillight (gray/red) is hot (12v)? To simplify, I am, instead of going to the taillight, wiring to an always hot fuse. Does someone have an accurate wiring diagram? Is this incorrect?
When I wire it this way (as indicated above), the light immediately pops the fuse. It seems the light switch itself is screwed to the rear lid and is thus grounded. So when I run power to the gray wire it shorts immediately as the gray wire is connected to the terminal which is part of the light switch itself. Is there a gasket between the light and the rear lid or am I just thinking about/ wiring this wrong? Something else I’m not thinking of? Thanks in advance
____________
'84 911 Targa
Old 11-02-2024, 03:43 PM
Check your engine bay light terminals at the light. One of the is grounded through the housing. Connecting the +12 volt lead to that would be a short to ground.
Old 11-02-2024, 05:44 PM
I’ll do it. Maybe they were swapped.
____________
'84 911 Targa
Old 11-03-2024, 04:20 AM
Thanks!
____________
'84 911 Targa
Old 11-03-2024, 04:21 AM
Where is the engine bay light? I don’t think my 84 has one.
Old 11-20-2024, 01:18 PM
proporsche's Avatar
every 911 from 1975-89 has an engine light
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-20-2024, 01:28 PM
Ivan
I think mine was removed. Can anyone post a picture of its location in the car and maybe a part number to buy a new one?
Old 11-20-2024, 01:33 PM
Found it: https://www.pelicanparts.com/More_Info/91163131501.htm
This thread shows a good picture of it mounted on the deck lid: https://forums.pelicanparts.com/porsche-911-technical-forum/975665-engine-compartment-light-wiring.html
Old 11-20-2024, 02:03 PM
proporsche's Avatar
our host have it...91163131501
Old 11-20-2024, 02:05 PM
