Ubi bene ibi patria
Headliner "Hold-down" Strips
Hi All
I am about to install a new headliner in a 1970 coupe. I would like to find a source and or a part no. for these strips: They appear to be constructed from a type of cardboard/paper material. Dims: 29mm (1 1/8") wide x 2.4mm (3/32") thick x 280mm (11") long. They are located at the base of the "C" pillar where the headliner transitions to a contact area under the parcel shelf cover They were originally held in place by spiral nails (?). I believe some form of sheet metal screw as a viable replacement for the nails would be a logical upgrade. Thanks in advance. Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
I just made some of these today out of thick brown posterboard…please post if you find a source
it's not leaking....it's just marking it's territory |
Soak them in warm water until saturated, lay on a flat surface, flatten them, put weights on them until dry.
Nothing better than original parts. |
