Born to Lose, Live to Win
Tach - where is 900 rpm. 83 SC
I believe each line below 1000 rpm is 250 rpm which would place 900 rpm just slightly below the 1000 rpm line, correct? Just confirming my idle is set properly
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
If you look only underneath the 1000 rpm it does look that way because there are only four marks. But in between all the other numbers are 5 marks, so I think each mark below the 1000 also represents 200 rather 250. So 900 rpm would be in between the 800 mark and the 1000.
That’s the way I see it. |
The tach is not very accurate under 1000 RPM. I would not rely on it. You really need a meter or timing light that shows RPMs.
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
OK thanks. Timing light should be here tomorrow
