Born to Lose, Live to Win
Wire loom in engine compartment question
I had my mechanic put in a new distributor green wire. He stripped off the protective wrap from the wires to exposure more green wire. There’s a 8” patch of wired without any wrapping
I assume the heat isnt good for the wires and I should wrap this. I rather not use something that will turn into a sticky mess or melt…..what is recommended? Am I right I shouldn’t leave them unwrapped so close to a ton of heat?
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
ROW '78 911 Targa
Ordered. Thanks
I’m sure you’ve had plenty of experience. What is your take on this vs Tesa tape? CTopher |
ROW '78 911 Targa
Depends on the variety of Tesa tape. Has a good name but expensive.
The one I posted is very good and very similar to what Porsche used.
Thanks for the link Dennis. I just ordered a roll as well
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
ROW '78 911 Targa
Most of the 69-83 cars only have small amounts of cloth tape. Mainly on the through body harness to tape off unused Sportomatic wires and to Seal up the rubber protector as they come out of the tunnel. Usually installed by the installer.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-06-2023 at 09:50 PM.. |
Need wiring supplies
Dennis,
I've seen several posts you've made on wiring. I see you build harnesses, but do you also sell bulk wire, connectors, and boots? I've just started on a 76 Targa that has been neglected for years. I need to go through all of the wiring, as much is brittle and broken. thanks in advance, Mac |
