-   -   CIS Mixture screw question (http://forums.pelicanparts.com/porsche-911-technical-forum/1144483-cis-mixture-screw-question.html)
harv666 08-08-2023 07:29 PM
Is there any sort of visual indicator that the screw is actually turning, my car currently wont start and I cant figure out if I need to turn left or right as I cant get it started? I know the screw pushes the sensor plate arm up or down is that piece of the screw visible from within the air box that may help me find center again? I dont feel anything moving when i'm turning it, also should it push the plunger down when you get it in the right spot?
fanaudical 08-08-2023 07:59 PM
There should be no need to adjust the CIS mixture screw just to get the car to run. Even a badly-adjusted idle mixture will still start with your foot in the throttle a bit.
Was it running previously and now won't?
Do you have spark? Compression?
What year car/motor?
harv666 08-08-2023 08:43 PM
Yes it was running up until I touched the mixture screw. I have spark and compression if I give it gas occasionally it will start but then dies when I remove my foot from the gas wont hold the idle.
1983 row sc
Schulisco 08-09-2023 03:18 AM
Probably a new basic setup is required supposing no vacuum leaks proved and every part of the CIS system is working properly. Again: Every part of the CIS must work in spec and no vacuum leaks!!
Vacuum leaks are the biggest enemy for CIS systems!!
I had exactly the same issue (engine won't hold idle speed when cold and a hard start and no start possible on ambient temps lower than 10°C/50°F) I purchased the car with lots of issues...
Conclusion: The mixture was way too rich due to several issues. I was able to keep it alive with the throttle as well...
With pushing the throttle you give the engine more fuel but also more air to burn it. I bet it smells heavy of fuel by holding it on idle with the throttle?
I your case I firstly would do a basic setup of the CIS. The procedure is described in detail by Curt form klassikats.com on his YT Channel in this video:
https://www.youtube.com/watch?v=K-OvjlkrgNo
But the whole video series about CIS is definitely worth a look before working on the CIS:
https://www.youtube.com/playlist?list=PLkWFofpgz2OgF9FdliKnlzuY0pygqRkMj
Good luck!
Thomas
eastbay 08-09-2023 08:38 PM
http://forums.pelicanparts.com/uploa...1691638566.jpg
