Porsche Crest SWB Rear Bumper Alignment
Working on my '67 911 and attempting to install and properly align the rear bumpers. There are 3 contact points under the frame/body and 2 connecting to the rear panel. Ive attempted spacers and I can't correct the sag on both outside corners. HELP!! any hacks or tricks to correct this?
Old 08-10-2023, 09:45 AM
PCA Member since 1988
I assume that the same as with the LWBs, in which case, you just have to band and put in spacers until it fits. These came from the factory with aluminum shims to get the alignment right. .
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-15-2023, 12:55 PM
Tags
1967 911 , body work , bumper , paint , rear bumper
