 I think they're two names for the same thing, green connector behind the airbox  |
 I'm starting to suspect I have a disconnected wire somewhere, like maybe a mouse gave something a chew. But if I have spark, shouldn't it fire? Especially when I sprayed fluid in the box?
	I know the PO liked to hook up lots of auxiliary electronic stuff, I'm even wondering if there's some anti-theft circuit he installed. Of course electrical stuff is my weak suit.  |
 Thomas,
	The injector does NOT spray when ignition is switched on; I tested it by lifting the plate in the airbox and activating the injector pump with ignition switch in the on position.  |
 Here's one example. I think I've seen it a number of times in this forum.  |
| All times are GMT -8. The time now is 04:04 PM. |
