no voltage light 76 911s 2.7
I have a 76 911s 2.7 that the voltage light does not come on with the key on. installed new battery, volage regulator, and had the alternator repaired and tested. Tested the light bulb, sanded the transmission ground and alternator gound. (still no light or charging) What should i check next.
chip
76 911s targa
Old 06-13-2003, 09:02 AM
also ther is no seat belt or door buzzer.
76 911s targa
Old 06-13-2003, 01:38 PM
pwd72s's Avatar
Just a wild ass guess...check fuses and relays...seat belt and door buzzer giving the clue.
Old 06-13-2003, 03:20 PM
Re: no voltage light 76 911s 2.7
if I assume wiring is OK..
then I would jump the inline noise suppressor that is on your engine electric panel.. report back because that suppressor causes problems with external regulated alternators..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-13-2003, 03:54 PM
thank you ronin
i bypassed the noise suppressor and now i have red light and charging
chip
76 911s targa
Old 06-14-2003, 12:05 PM
pwd72s's Avatar
Score another one for Ron!
Old 06-14-2003, 03:59 PM
