Door lock pull pins?
I'm swapping my door cards over to the RS-style ones and looking for a way to delete the (admittedly cool) circular lock knob. I've noticed a number of cars on here that don't have it, but I haven't been able to determine what they do for a longer pull pin atop the upper door garnish. At least, I'm assuming that's how they lock/unlock the car from the inside.
Old 08-02-2021, 08:51 PM
evan9eleven's Avatar
Looks like TeeJay never got his question answered above, and I have the same conundrum. Photo for clarity, anyone know what thread this rod has on an SC?
Rennline makes door lock pins for all our models, and the long ones needed for an F-model are a different thread than for a G model which normally has the shorter pins. 4mm is too small, 5mm too large. Anyone know?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 05-29-2025, 11:45 AM
It's a 5mm thread (M5-0.8) …I put a nut on it to be sure. The original plastic pulls seem tight going on a sample 5mm bolt but that’s probably due to being old plastic compound or inner thread worn.
Rennline aluminum should have proper tolerances.
Old 05-29-2025, 01:06 PM
Thanks! This was a big help.
An M5 nut threads on mine rather loosely so something seemed off. But with the long threaded pins should be fine.
The long version of the Rennline aluminium pins I have (spec for up through model year 1976) are a smaller thread dimension then on later cars but will not accept an M4 bolt, while an M3 is too small. In any case, I'll drill and tap the Rennline parts out to M5 for my 81.
2004 Boxster S
Old 05-29-2025, 01:54 PM
famoroso's Avatar
Which pins did you order? I need to extend the lock rods on my ‘89 3.2. I’ll drill & tap to fit.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 06-16-2025, 08:47 PM
I've been trying to figure this one out as well. would like to keep the original look though. There's got to be pulls from another vehicle that would work?
'83 911SC - Rubinrot Metallic
IG: @911.sc.83
Old 06-16-2025, 09:12 PM
My Ford F150 plastic pull pins are 1-5/8” long not certain on the thread size (a loose 5mm) I just tried and they fit onto the 911 threaded rod and a wee bit .5mm thinner O.D. but not noticeable in the opening. So you may get than extra length needed to reach a shorter rod.
They might have these and similar pulls on shelf at most auto parts stores AutoZone etc.
Btw…911 pins are about 7/8” long.
Here’s some pics -
Old 06-17-2025, 01:13 PM
I got the pins for 65-76 models, Rennline part nr. DH06. I drilled and tapped to M5 as mentioned above, the challenge (besides drilling them perfectly) is finding a tap long enough. I'll eventually tap mine deeper.
https://www.rennline.com/rennline-aluminum-door-lock-pins-set-porsche-sku-dh06/
2004 Boxster S
Old 06-20-2025, 07:48 AM
