| Registered |
				3.2 oil pump in 3.0 sump plate?
			If I use a 3.2 oil pump in a 3.0 will this sump plate work? I would like to have a drain plug if I have to update the pump.  Here's the link to the product: https://www.pelicanparts.com/More_Info/MCD99310700100.htm?pn=MCD-993-107-001-00
				__________________ Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche | ||
|  09-27-2023, 04:14 AM |
| It's a 914 ... Join Date: Jan 2008 Location: Ossining, NY
			Took a look at the pics in the ad. It does appear to be for the later style oil pump with integrated screen, and the ad does say that it's for turbo and 993 pumps which is consistent. The key is the plate needs to be concave to match the contour of the integrated screen on the pump, and not the earlier flat style sump plate.
|  09-27-2023, 05:07 AM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			Beware low hanging hardware and raised manhole covers, etc. You pays yer money and you takes yer chances. From the looks of the thread depth, not much screen clearance in there.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 09-27-2023 at 07:00 AM.. | ||
|  09-27-2023, 06:58 AM |
| Registered |
			So what are my options if my 3.0 pump is shot? I only see 3.2 pumps available new.
|  09-27-2023, 08:45 AM |
			I think John may be referring to the sump plate. A later style factory sump plate is an option - the kind with the hemispherical shape instead of flat.
|  09-27-2023, 08:59 AM |
| PCA Member since 1988 |
			Yes, you can use a 3.2 pump.  You may have to do a little mixing and matching with the sump plate and screen.  No biggie. And as JW suggested, don't buy a sump plate that hangs down.
				__________________ 1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! | ||
|  09-27-2023, 02:21 PM |
			Here's the factory sump plate I was mentioning above https://www.pelicanparts.com/More_Info/93010190200.htm?pn=930-101-902-00-M260 | ||
|  09-28-2023, 03:56 AM |
| Registered Join Date: Jun 2009
Plenty of used 3.2 pumps around, I have several.  Bob
|  09-28-2023, 11:12 AM |
