Tod repairs
Hi
I've been working on the 1981 911sc euro oil warning light switch to replace because of leaking. I did a partial engine drop but I can't feel the switch after lowering 2-3 inches Any ideas would be appreciated Thanks Barry Last edited by Bass911sc; 08-26-2023 at 08:41 AM.. |
I take the boot off. no drop needed. 24MM deep socket and extension. Mirror and flashlight.
Hi thanks for info I read about the cis boot but the nut to loosen are in a bad position. I will look again
PCA Member since 1988
John is referring to the rubber boot on the top of the CIS. Remove it and you can get to the switch. Sometimes those large hose clamps on the boot rotate and are hard to get to. Just do what you have to to get it off. If it's old, you might be able to pull up and get it off. If it's the original boot, it probably has cracks and should be replaced anyway. Pelican sells them for about $110.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
If the clamps rotated then they weren’t tight to begin with or loosen over time, they just might pry up. Here’s a good link
Edut: the link doesn’t load. Look up Joe-engineer’s site. https://******************/diy-how-to-replace-the-cis-intake-boot-on-a-classic-air-cooled-porsche-911/ |
