Gunson gas tester
I bought a Gunson gas tester online and it arrived with no tubes or gas probe to hook it up . It will be returned. My question is how the the tester analyze the gas when the tubes just hook into the plastic piece on the back. In other words , I don’t see how any gas goes into the actual tester.
Old 07-06-2023, 08:29 PM
Flex tubes plug into the fittings in the top pic and couple on to an aluminum tube that is inserted into the test port in the cars exhaust. That one you have there looks unusable the way it is. It looks like its been delivered by Ace Ventura!
Old 07-06-2023, 09:25 PM
Maybe the disc is the collector and the big box is the analyzer? Mine broke and I tossed it. Kind of wish now I had cracked it open.
Old 07-06-2023, 09:27 PM
I see what you are saying but if you look at the picture, the plate part came unglued from the machine and I see no hole there for gas to get into machine to be analyzed. How could gas be analyzed if no gas gets into tester. You can see that both parts were together when new. The gas to be analyzed seems to me to go nowhere!!
Old 07-06-2023, 10:07 PM
I must be missing how this thing works. The part is just glued onto the back of the machine. I read that it is very common for it to come unglued. Anyway, it’s going back to the seller.
Old 07-06-2023, 10:32 PM
Schulisco's Avatar
Refer the single page "manual", this shows the content of box and the hoses delivered with.
https://www.gunson.co.uk/product/G4125/Gastester-Digital
The sensor is in the round disc where the hoses getting connected. There's no pump sucking the exhausts in. They have to flow to the sensor when engine is idling. Therefore it rerquires a moment until measurement is possible. Simple, very cheap, but working. Unfortunately with a tolerance of 0,5% not sensitive enough for injection cars with catalyst, because they have to keep a CO value between 0,4-0,8%...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 07-07-2023, 01:10 AM
Ok , the round disc is the sensor, but how does the information from the gas get to the digital readout on the tester when disc is not connected to the tester? My Gunson was delivered apart and there is no “ in “ port on the tester. So how does it read ?
Old 07-08-2023, 07:10 AM
That's the product description. The "full instructions" they refer to in that description may be found online. This https://images-eu.ssl-images-amazon.com/images/I/91Ihi6jU31S.pdf worked for me.
Or there's a 7 page handbook: https://www.manualslib.com/manual/1482901/Gunson-Gastester-G4125.html#manual
and a 20 page handbook (eh? do what now?) https://www.manualslib.com/manual/1380847/Gunson-G4125.html
and a 2 page "supplementary adjustment procedure" document https://www.manualslib.com/manual/2226550/Gunson-Gastester-Digital-G4125.html#manual
LOL - "a moment"... I had one, used it once. Seemed to agree with my wrench's 5 gas analyzer fairly closely - and, to be fair, didn't cost $5000...
That said, they are both inaccurate and slow... An initial 8-10 minutes for free air calibration (the "supplementary adjustment procedure says "allow to warm up for minimum of 15 minutes"), initial reading after 15 seconds, observe for another 1-3 minutes, allow "at least" 1 minute to stabilize between adjustments, leave powered up "at least" 10 minutes after motor shutdown for exhaust gas purge etc.
The stated accuracy of +/- 0.5% in the range 0.5% - 6.5% CO?
Although mine seemed somewhat better than that (actually, pretty much dead-on), that stated accuracy is the same difference between 3.0% CO and 3.5% CO - which, for idle on a CIS 930, was the difference between "runs correctly" and "cyclic lean surge on fixed throttle under light load".
'77 S with '78 930 power and a few other things.
Old 07-08-2023, 08:45 AM
This may help:
Old 07-08-2023, 08:55 AM
Again , no gas goes into the tester. How does the digital readout change ?
Old 07-08-2023, 01:35 PM
Magic!
I tried to use a friends tester gave up and bought a innovate wide band O2 kit and use the O2 bung.
Old 07-09-2023, 07:37 AM
The first one I bought was broken in transit. Not as bad as yours, mine had the water trap popped loose. I was worried that internally it may have sustained some damage. You and I can’t be the same ones. Even the Chinese package better than what I received. To rephrase, the Chinese company that made these is less proficient at packaging. It seems like they would have a better profit margin if they corrected their packaging.
Old 07-09-2023, 08:19 AM
The exhaust hose goes to the pulse pump/water trap. The actual sensor is in the "collector box" (the bit that came unglued that the pulse pump is mounted on). There's an electrical pigtail between that sensor and the main box that houses the display and the electronics.
Old 07-09-2023, 10:04 AM
Yes ! Was a terrible package. I bought from Mercari a site like eBay. They sent me a postage label to send it back. I however put it in a correct box. I’ll get my money back.
Old 07-09-2023, 02:06 PM
Got my money back !
Old 07-14-2023, 06:45 PM
Got my money back !
Are you going to rebuy?
Old 07-14-2023, 06:58 PM
Yes ! When I can . The return worked smoothly.
Old 07-14-2023, 10:43 PM
I have a good Gunson with instructions and 2 probes if you’re interested
Old 08-23-2023, 11:01 AM
AndrewCologne's Avatar
...Therefore it rerquires a moment until measurement is possible. Simple, very cheap, but working. Unfortunately with a tolerance of 0,5% not sensitive enough for injection cars with catalyst, because they have to keep a CO value between 0,4-0,8%...
Mine needs about 10 mins to calibrate itself in environment air, after that ist quite accurate and hits the final CO very close, compared with professional exhaust testing systems at emission testing shops like DEKRA/TÜV etc.
The values 0,4-0,8% are just for the initial setting, finally with active control at lambda 1 on these engines it results in up to approx 1.2 % CO where then the cat converts internally with up to 90% efficiency down to approx 0.1 % CO.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 08-24-2023, 01:30 PM
They do work pretty good for what they are, mine compared with the latest MOT test, was pretty much the same as how I set it!
I agree though, they can be a bit fiddly to use.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 08-25-2023, 08:06 AM
