-   -   Weird fuse box jumper wire? (http://forums.pelicanparts.com/porsche-911-technical-forum/1145535-weird-fuse-box-jumper-wire.html)
rywats 08-29-2023 07:13 PM
I’m at a loss - why would I have this jumper wire running from my fuel pump fuse ( 3 ) to my turn signal and back up light ( 8 )?
82 SC. Everything works as it should.
Thoughts?
rywats 08-29-2023 07:19 PM
http://forums.pelicanparts.com/uploa...1693365585.jpg
rywats 08-29-2023 07:22 PM
http://forums.pelicanparts.com/uploa...1693365735.jpg
timmy2 08-29-2023 10:05 PM
It is actually fuse 11 supplying switched power to fuse 16 (using Porsche numbering on the factory schematics Fuse 1 is closest to the headlight) ignore the numbers on the fuse panels.
There was no internal bridge to that unused fuse position when they added the fuel pump relay in 76. So they added a jumper.
rywats 08-30-2023 04:52 AM
Hi Timmy, I appreciate the response.
Thank you.
john walker's workshop 08-30-2023 06:39 AM
Been overheating at the fuel pump fuse terminal, too.
rywats 08-30-2023 04:35 PM
Yes - and there was some corrosion on the wire too. Not quite sure why? Failing fuel pump drawing too much amperage?
timmy2 08-30-2023 10:35 PM
41 years of service on a jumper wire will do that too.
