condensor fan Part Number help
The front condensor fan motor is T.U. Does anyone have the OEM part number? I will be needing the swirl cage as well..the cage was rusted to the shaft and I had to drill the rusty allen set out.
These fans are under the front end and get a lot of abuse without notice. I happen to notice the outlet temp of the cool air into the car raising while sitting at the stop lights and though that I would do some looking and guess what?
Bob 80SC |
Bob, the full assembly is 911.624.013.01 (fan, air duct, etc), let me know if you need the individual part numbers.
regards
Jordi Riera '84 930 (modified) |
Jordi,
I could use the fan part number and the cage number if you have time?
Bob 80SC |
fan: 911.624.151.05
Gasket: 930.573.171.01 (fan to air duct) Air Duct: 930.573.065.00 Gasket: 930.573.173.00 (air duct to air deflector) Hope this helps.. check your PM in a short while
That will get me started ...thanks
Bob 80SC |
