-   -   Adjusting valves Just before TDC? (http://forums.pelicanparts.com/porsche-911-technical-forum/1145571-adjusting-valves-just-before-tdc.html)
wellinginc1 08-30-2023 02:10 PM
I noticed while adjusting my valves, that the most amount of slack I found was just before TDC and on the other cylinders just before the 120 degree mark rightfully.
If I continued onto TDC it tightens up a bit. I have a feeler gauge that I used and set them to on their rightful strokes. However if just before the stroke there is all this slack Im feeling, wouldn't that be a case for concern?
Classic 911 08-30-2023 02:20 PM
Following
Walter_Middie 08-30-2023 03:02 PM
Wellinginc1,
You should watch a YouTube video on how to do this:
https://www.youtube.com/watch?v=DQI9OR0Vt4w
If the engine is in the correct position for valve adjustment, rotating the engine several degrees should not make any difference. The cam lobe should be on the "base circle" during valve adjustment.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fegnation.com%2F2016%2F1 1%2F21%2Fall-about-that-base-circle%2F&psig=AOvVaw1aE1t91tq8LYFt-iISzzu3&ust=1693523278535000&source=images&cd=vfe& opi=89978449&ved=0CA8QjRxqFwoTCJjkx_-_hYEDFQAAAAAdAAAAABAE
boyt911sc 08-30-2023 03:30 PM
Correct Stroke………
Are you sure you are doing the valve lash adjustment at the right stroke (Z1 compression)?
Tony
icarp 08-30-2023 07:15 PM
sounds like you r in valve overlap for the cyl u r adjusting.
not compression stroke
