Swallowtail's Avatar
Where does the lower tank bolt connect to?
Hi everybody,
unfortunately since it's been years since I took my 911 apart I don't remember how everything goes together.
I just installed the oil cooler just with the upper to bolts that go through the inner sidewall. Right not the tank is touching the flange on the outer shell because it's sitting too far out on the bottom.
There is a tab with a weld on nut on the bottom but I don't see where it’s supposed to be attached to the chassis.
Appreciate the help!
Old 09-01-2023, 04:30 AM
proporsche's Avatar
you are missing body bracket to fender ext. and little bracket to the oil tank
Ivan
you need the one on the left https://i.ebayimg.com/images/g/nqEAAOSwuxpZbRbz/s-l1600.jpg
1985 911 with original 502 191 miles...808 198 km
Old 09-01-2023, 05:05 AM
Ahh, now I get it! My car came with a plastic rear fender so I have to buy the two tubes and the bracket.
Thanks a lot!
Old 09-01-2023, 05:09 AM
