Door pocket for 911 from 1973
Hello!
Does anyone have a picture of how this rubber strap loops around the door pocket?
I suppose I need this plastic strap holder as well
Cheers
Old 08-27-2023, 04:37 AM
The bungee enters the pocket via the upper hole, then through the clip, and out the lower hole. Some substitute a knot for the clip. Make sure the bungee has lots of give and not too tight, as it can lead to distortion of the pocket. Rob
Old 08-27-2023, 06:50 AM
Porsche Crest Thanks Rob
Now I understand
But it must be difficult to tie a knot behind the pocket when it is halfway closed, and especially the rear rubber cord.
Probably go for the Clip-option. Is there a special clip for that, or just inventing something ?
Old 08-27-2023, 09:29 AM
Your cord may not be correct. The factory used black sheaved bungee, not rubber cord. Bungee cord has lots of elasticity. Easier to work with, less stress on the pocket.
Your picture above shows the correct clip if you go that route. Rob
Old 08-27-2023, 12:07 PM
I ordered the cord from rosepassion.com so it should be the right one. But I've received many low quality or non-fitting parts from them.
It is stiff and I will use a bungee instead.
Old 08-28-2023, 11:51 PM
Cool
Was looking for what screw to use for the front pocket ( still looking) when I found this picture.
So there's one cord per door and it continues from the hole under the armrest to out of the hole in the bracket with the arm.
This picture is from the service Manual
Old 08-31-2023, 08:56 AM
Sierra Madre has the correct part.
Part number SMC.911.158.50
Old 09-04-2023, 04:15 PM
